Announcements
I PAID FOR IT, NEED IT TO WORK!
gustavo.ferro
Observer Observer
gustavo.ferro
Observer
Observer
AUTODESK, need it fixed the menu bar all black/white fixed.
THANK YOU.
HughesTooling
This should be fixed in the latest version. Did you use the environment variables in the past as a workaround, if so you need to remove them. See this post. If not and this is the first time you've had the problem the easiest fix might be to uninstall then reinstall. Or you could just add the environments variables temporarily so you can see when the new update has downloaded, close Fusion then remove the environment variables before restarting Fusion.
Mark
Mark Hughes
Owner, Hughes Tooling
