I'm stuck on T-spline surface is not extractable
christianiuliano
christianiuliano
Could someone please help me turn this form into a 3d printable file without changing the body too much. I'm stuck trying to change the body and it's giving me a t-spline surface error.
dsouzasujay
Hi @christianiuliano
The details are not enough to understand the problem.
Could you please export by File>Export *.f3d/*.f3d file to your local drive and then attach it here to a reply.
and also a video/image explaining problem will help us.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
christianiuliano
I am trying to make this form into a body so I can 3d print it. Trying to get it as an stl. Thanks
glenn-chun
Attached is the model that I manually repaired. Your original model had the following problems:
1. Some faces intersect other faces.
Recommendation: Use Edit Form in Box Display mode to move faces, edges, or vertices to avoid self-intersections.
2. Lack of topology flows.
Recommendation: Watch Topology With T-Splines In Fusion 360.
3. T-Points are right next to Star Points, causing bad surface quality.
Recommendation: Use Insert Edge or Insert Point command to position T-Points at least two faces away from a Star Point.
4. L-Points exist, causing bad surface quality.
Recommendation: Make quads (four-sided faces) to remove L-Points.
Hope this helps,
Glenn
Glenn Chun
Sr. Principal Engineer
christianiuliano
Thanks so much
