Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
I'm stuck on T-spline surface is not extractable
4 REPLIES 4
christianiuliano
506 Views, 4 Replies
Could someone please help me turn this form into a 3d printable file without changing the body too much. I'm stuck trying to change the body and it's giving me a t-spline surface error.
4 REPLIES 4
Hi @christianiuliano
The details are not enough to understand the problem.
Could you please export by File>Export *.f3d/*.f3d file to your local drive and then attach it here to a reply.
and also a video/image explaining problem will help us.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
I am trying to make this form into a body so I can 3d print it. Trying to get it as an stl. Thanks
Attached is the model that I manually repaired. Your original model had the following problems:
1. Some faces intersect other faces.
Recommendation: Use Edit Form in Box Display mode to move faces, edges, or vertices to avoid self-intersections.
2. Lack of topology flows.
Recommendation: Watch Topology With T-Splines In Fusion 360.
3. T-Points are right next to Star Points, causing bad surface quality.
Recommendation: Use Insert Edge or Insert Point command to position T-Points at least two faces away from a Star Point.
4. L-Points exist, causing bad surface quality.
Recommendation: Make quads (four-sided faces) to remove L-Points.
Hope this helps,
Glenn
Glenn Chun
Sr. Principal Engineer
Thanks so much
