Announcements
I keep getting (Fusion 360 not responding) when i change a parameter
DamienBell19
DamienBell19
I recently updated from a HP envy laptop running Ryzen 7 because every time i changed a parameter or even a simple task like adding a measurement to a sketch i would get (fusion 360 not responding), so i have updated to a pc running
Ryzen 5 3600
16gb DDR4 RAM
RX570 8gb GPU
 and much to my disappointment it didn't make any difference.
Any suggestions would be greatly appreciated.
Phil.E
Thanks for posting. In this case the diagnostic logs aren't much help. Those show web traffic. What you are describing is local to your computer/design.
After changing computers, are you finding the issue in a single design, or if you start a blank design and draw a circle, does it happen then? This is key, because changing parameters will trigger a parametric compute, and in some larger more complex models, you may find Fusion not responding for a short time. So it helps to know if it's one design that shows the problem, or also blank new designs.
If you could share the design file (File > Share public link) or even just a screen capture image that includes timeline and browser, it would help to figure out what's going on.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
