I have created the p-clamp with using configuration option. I'm facing the model error one more configuration 2. Configuration 1 is working perfect.
pulaver_
pulaver_
Configuration 1
length:15mm
Wire daimeter:3mm
Configuration 2
Length: 16mm
Wire diameter:5mm
Configuration 2 I am facing the issue and warning (Failed to resolve. Please try revising dimensions or constraints)
Please help me to resolve my error.
jhackney1972
You need to attach your model so the Forum users can find the error.  A picture helps but the model is needed.  Open the model, select the File menu, the Export and save the file to your hard drive.  Attach it using the attachment section of a reply post.
John Hackney, Retired
pulaver_
Please find the attached file.
jhackney1972
You went a little overboard with adding sketch constraints.  I removed a lot of your Symmetrical constraints and replaced them with horizontal and vertical and a few others.  I find symmetrical sketch constraints, especially with used in excess, can lead to problems.  Model is attached.
pulaver_
Thanks a lot. It's working fine.
