Fusion Support
I have a probleme with the visibility of the volume
2 REPLIES 2
thomas_spangenberg
76 Views, 2 Replies
What have I been doing wrong in Fusion since today?
I checked also the view with Ctrl+4 and Ctrl+6 and then Ctrl+9. I somehow miss the complete shape of the volume after extruding. For example, when I create a cylinder or cube, you can't see the shape at all after extruding.
The STL is then completely normal in the Orca Slicer when I want to 3d print.
When I load in my recent data components, everything fits and is fine and I can see everything as normal as it was. I double checked it also on my laptop and I have the same probleme there.
Translated with DeepL.com (free version)
2 REPLIES 2
Please share the file.
File > export > save as f3d on local drive  > attach to post
günther
@thomas_spangenberg
Are you in an active Section Analysis?
