I have a plane, but I can't sketch on it.
kuji21ni
Observer
kuji21ni
Observer
Observer
So I am modeling inside someone else's assembly and I am trying to build a new component in it. I have successfully created a plane, but when I try and sketch on it my lines just disappears and I can't sketch on it. And thus can't make the component. Tried to find any solutions, but could not figure out the problem.
g-andresen
please share the file for investigation
File > Export > save as f3d on local drive > attach to post
günther
kuji21ni
Observer
Observer
I am under NDA. So, I can't. Sorry.
HughesTooling
If you rotate the view a bit do they show? I've had occasions where looking straight on at the sketch plane the lines disappear.
Mark Hughes
Owner, Hughes Tooling
g-andresen
1. Did you create the plane with Construction tools?
2. Create a sample file and share it.
günther
TheCADWhisperer
Show your expanded browser.
Are you in an active Section Analysis?
kuji21ni
Observer
Observer
Ended up getting help from a coworker. Object visibilitet was not on...
