Fusion Support
I Downloaded a Model tank of the internet. when i converted the mesh it all became a surface body not a solid body. Please help
2 REPLIES 2
ARNOLDJT
119 Views, 2 Replies
I Downloaded a Model tank of the internet. when i converted the mesh it all became a surface body not a solid body. i have watched many videos saying that I need to stitch but the stitching doesn't work. if anyone can help that would be AMMAZZINGG,
Thanks!
Tags (2)
2 REPLIES 2
jhackney1972
in reply to: ARNOLDJT
You need to "repair" the mesh model before converting it.  Choose the icon I indicate and then use the "Close Holes" repair type.  After this you can convert it.  Converted model is attached but please, try it yourself.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
ARNOLDJT
in reply to: jhackney1972
Thankyou So Much!!! It worked
