Announcements
I cannot measure the distance of two edges
hajime2MRG3
hajime2MRG3
I am curious why I cannot measure the distance of two edges in this case.
Replies (7)
jhackney1972
The measure command is reporting the length of the selected edges.  The distance between the two edges has an infinite number of possibilities so it cannot report it.  Strike a line across the two edges where you want to take the measure at and use the two points where the line crosses the two edges.
John Hackney, Retired
jhackney1972
You can however switch to Body selection and get the minimum distance.
hajime2MRG3
I am curious too about the meaning of "distance" in this case. I have no idea how F360 picks the two points.
jhackney1972
With the Distance between Bodies, it is the minimum distance point between the two bodies wherever is may be.
hajime2MRG3
In most cases, that is true. But in this case, it isn't.
jhackney1972
I would like to see the model to see what you are looking at.
jeff_strater
it looks like this is specific to this model.  In general, the distance between two edges or bodies should be the minimum distance.  In this model, though, it does not look like it is functioning correctly.
I've created bug FUS-99831 to track this issue.  Thanks for bringing it to our attention
Jeff Strater
Engineering Director
