Hello thrjesse,
I took a look at this. There is a problem with shelling at the nose of the boat and at the windscreen (do boats have windscreens? I don't know). The difficulty is that the diffferent surfaces in these areas can each offset but the offset surfaces won't "glue up" to make a watertight sheet. Cropping these regions away (combine-cut) leaves an adjusted boat shape which will shell to, say, 2mm.
I imagine that you don't want a boat that's this shape; you need that nose shape as you designed it on the outside of your shell but maybe it's not so important what the shape of the inside is.
I started to put together a longer timeline to demo how to build a model with your boat as the outside and the adjusted inside shape (I would offset a surface model and then use that offset surface body as a tool for split-body), but I decided to hold off - I'm not sure what thickness you're really after, or what shape you want around the top of the boat - do you have an idea of some "open faces" for the result you seek? Or are you seeking a complete hollow boat with a void space inside?
Jean Flower
Product Manager
Autodesk, Inc.
