I can't seem to select a Post Processor (Centroid)
cmstewart21
cmstewart21
When I go to select a post processor from the Library, I get this dialog box and I can't get through it.
I need to use the Generic Centroid PP. When I click to select a location (not sure what the location is for), I can't select anything. I can't select the library, or my local HD (it says there's no location found). So I don't know what to do.
Thanks for the help.
engineguy
@cmstewart21
Have you tried Right Click on the highlighted PP, then select "Copy", next just place your Cursor on your "Local" library without clicking and then Right Click and select "Paste" and the PP will then be in your Local PP Library and you should be able to access it from there.
cmstewart21
Ah, that worked. I don't know why it won't just let me use it from the library, but I guess for now I'll just use it locally. Thanks for the solution.
engineguy
@cmstewart21
Tip, for what it`s worth you shouldn`t really be using your PP from the Fusion Library as the PPs often get changed during Fusion updates, so always keeping any PP that you know is good in your Local Library or your Cloud Library is best practice, also save a copy of it in a folder somewhere on your computer so if you get any issues you can simply Copy/Paste the good one back in 🙂
Also, again if you have a known good PP you should go to your "Preferences" and disable the "Automatic Post and Machine Updates" as shown in the image below.
