I attached a screen shot: I projected a curve from the edge of a 3D surface on to a 2D sketch. I now want to offset this curve on this new plane a few mm forward, but I can't select the curve. It will highlight blue when I hover over it, but I cannot select it. I tried just extruding it as a surface as a workaround in order to offset the new surface, but it wouldn't let me extrude the curve--even though it's from a flat plane.
The weird part is: I've actually performed this exact action in Fusion 360 in the past with other designs and it never failed before. Does anyone know what is causing this issue/how to get around it?
