Fusion Support
I can't export files but .f3d
2 REPLIES 2
u468702d
99 Views, 2 Replies
I cannot convert my models into other file extensions, such as .stl or .dxf.
After clicking 'export,' Fusion 360 initiated the conversion process in the cloud. However, the task has not completed even after several hours. I attempted to reinstall the software, but the situation did not change. What can I do?
2 REPLIES 2
g-andresen
in reply to: u468702d
1. STL  :  Browser > Body > rightclick >save as mesh (STL/3mf)
2. DXF :  Browser > Sketch > rightclick > save as DXF
günther
u468702d
in reply to: g-andresen
I couldn't export more than two objects in one file by using the method
you taught me, but I could export them by using Fusion
Team(https://myecs826.autodesk360.com/g/all_projects/active). thank you
very much for your help! 🙂
