Announcements
I am unable to display wireframe.
Inspections_JCH
Inspections_JCH
This post is the result of a similar post that I started in the Manufacturing forum. In that post, I thought that I was simply not understanding the way to display wireframe.
During the discussion I realized that if I started from scratch with a new file, I could easily display the wireframe. Further tests, revealed that the file itself had gotten into a state that would not display properly.
I am not able to tell you all the steps I took to put this file into this condition, but it seems to be stuck with no way out. Notice the missing lines.
jeff_strater
it looks like an opacity has been set on both the root component, and the "200x300 Rectangular Block for X-Carve test" component.  It looks a bit like perhaps something went wrong with the auto-dimming during component activation, that is, if you don't remember setting an opacity manually - I think the same attribute is used.  Would be very interested in a set of steps to get back to that state from a new file, if you ever find such a thing
Jeff Strater
Engineering Director
