I am not able to run Fusion360
My system is windows10 up to date. Geforce RTX2060,16G.
I have no idea what happens, it was working every day before.
This morning, It doesn't work anymore. I can't run it without any pieces of information coming, I have clicked on the icon for few times, but nothing happened. and then I have restarted my laptop, which still doesn't help. and then I delete Fusion360, restore it again, but still not able to run.
Anyone who can help?
HughesTooling
Maybe try a clean uninstall then reinstall. Use the uninstall tool here.
Mark
Mark Hughes
Owner, Hughes Tooling
g-andresen
Did you do the obligatory CLEAN UNINSTALL before reinstalling?
günther
RajkumarIlanchelian
If the above suggested clean uninstall does not work, can you please follow what is being asked in this thread? https://forums.autodesk.com/t5/fusion-360-support/fusion-360-crashes-on-start-urgent/m-p/10726201/hi...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
flo3A3SN
I had the same problem.
What i did when it didn't work: sketch --> extrude --> flange didn't work.
But if i flange my sketch from the beginning, so creating the first body using flange instead of extrude, it works fine after that. So: Sketch --> Flange --> Flange 😉
Hope this helps.
