Announcements
HSMWorks Machining in air when in Machine Simulation
dave.hardy
Observer
dave.hardy
Observer
Observer
Hello -
Been using HSMWorks with SolidWorks for a couple of years.  No formal training on HSM, but a fair bit of YouTube University has gotten me fairly proficient at the 2.5 axis machining I'm typically doing.  I'm considering adding 5th axis to my machine (Haas TM3P) and before I pull that trigger I wanted to make sure I could actually be productive on it, so started trying to make some toolpaths.  I've never used Machine Simulation before, but with the additional axes, I wanted to learn that to keep me from crashing.
I went ahead and built out a machine and equipped it with the 5th axis unit I'm considering.  I was able to get it setup, I believe correctly, using this vid - https://www.youtube.com/watch?v=dJuArpNenJ4
When I just run a simulation of my part, it machines correctly.  But if I do a machine simulation, it's nowhere close to the part.  The axes all look like they are behaving correctly, but I'm machining air that is ~12" above my part and 4" to the left of it.  I'm guessing there's some kind of offset issue, but everywhere I've found to tweak offsets doesn't fix it.
There's a screen cap below where you can see what I see during a Machine Simulation run.  The red toolpath line shows what it thinks it's drilling, and the Z motion is infact drilling motion, just not in the part.  The various other faces rotate around correctly and the drilling continues, just with that same offset.
Machining airMachining air
Any wisdom????
Replies (0)
