Announcements
HSM Edit will not load
tomGKJVK
Message 1 of 8
tomGKJVK
About 6 months ago HSM Edit stopped working on this computer.  It will no longer load when posting a program with the check box checked, and if I try to open it manually I get "Please open Autodesk HSM to run Autodesk HSM Edit".
I have completely uninstalled and reinstalled Fusion since and it did not fix the problem.  Would be nice to get this working again.
Replies (7)
Message 2 of 8
seth.madore
Autodesk HSM Edit runs a check in the system every 20 days or so to determine that you have the proper software installed. Fusion is not what it checks, but rather, Autodesk HSM or Inventor CAM. Once either one of those are opened up, it sets the check to "valid". Do you have either of those installed on your PC?
Seth Madore
Message 3 of 8
tomGKJVK
No I do not. I had installed a demo of Inventor a long time ago.   Maybe that's how it got on the system.   How do I get the editor that comes with Fusion working again?
Message 4 of 8
seth.madore
Go to Preferences > Manufacture and clear out this box:
Seth Madore
Message 5 of 8
tomGKJVK
That box was already clear.
Message 6 of 8
seth.madore
Then you would need to set the search path to another editor of your choosing, such as Visual Studio Code, Notepad++ or plain old "Notepad"
Seth Madore
Message 7 of 8
tomGKJVK
Visual Studio Code originally installed with Fusion, but is no longer on this computer.  Reinstalling Fusion didn't restore it.   How do I get it back?
Message 8 of 8
tomGKJVK
nevermind.  i just realized VSC is a free third party download.  Installing now.  Should be good to go.
