Announcements
How to write a greater than parameter. if greater than or equal to height subtract .125
john_chipukites
john_chipukites
I am trying to write a parameter in fusion 360 that if the height is greater than or equal to .5in it will subtract .125. What I have now is below and it doesn't work. Not sure how to write the function so fusion will read it, any help would be appreciated.
if( Height >= .5 in ; - .125 in )
Thank you
John
HughesTooling
It needs to look something like this.
Mark Hughes
Owner, Hughes Tooling
jhackney1972
The If function requires two arguments, one if the if function is true and one if the if function is false.  You forgot the second argument.  Below is an example.  In this example the false value is "1.0".  Model I used it in is attached.  Change the "Height" variable to a value larger than 1.5" and the "New Height" will become .125" that the "Height" variable.
John Hackney, Retired
john_chipukites
That's what was missing.
Thank you
John
g-andresen
just take a look at the Product Documentation
günther
