How to twist a Body
samuel.mattio1214
How to twist a Body
samuel.mattio1214
Hi! im looking to create a body that has 2 characteristics as shown in the pictures, but i cant create one with the two at same time, any idea how to make it? I use  sweep for both, in the one that doesnt twist i can use Path + Guide rail, but again, i cant twist it! And if i use only Single Path, i can twist it but i cant make the top bigger than the bottom! Thanks.
WHolzwarth
Perhaps like that?
Walter Holzwarth
samuel.mattio1214
For some reason i cant see it, maybie you can make a screenshot? or convert to another format? Thank you!
samuel.mattio1214
Sorry, i already open it! its perfect. I dont understand how you do the lines following the body in the sketch 6
WHolzwarth
That's strange. Here's a picture.
Later: Project to Surface does it (3D curve creation).
Right-click on Sketch6 in Browser -> Edit Sketch -> Click on CREATE in top-line -> Follow screenshot
Walter Holzwarth
samuel.mattio1214
So, im trying that but doesnt come out  šŸ˜«, i dont know what im doing wrong, i select as faces the body, and curves the spline
samuel.mattio1214
I do it! in vector mode! Really thank you for the help!
