Fusion Support
How to turn bodies into plans for table saw cuts?
3 REPLIES 3
glennjkrause
121 Views, 3 Replies
I have this model where each wall (piece of wood) is precut into the model. How would I exactly get the cuts onto a 2d sketch/plan (also with the various cuts at angles)?
Labels (1)
3 REPLIES 3
Drawing
@glennjkrause
Please don't mind the lack of organization (I have barely beginners' knowledge).
jhackney1972
in reply to: glennjkrause
I did a video on creating a 2D drawing from one body at a time.  You can do more than one at a time but that will mean extra management in the drawing.  I also show how to Rotate your view after placement to aid in dimensioning.  Let me know if you need further help.
Edit: I would like to suggest that you explore the use of Components as soon as possible in your use of Fusion 360.  They will make your designs easier to build and easier to document.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
