Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
How to test balance using Centre of mass
3 REPLIES 3
oliverchatwin
314 Views, 3 Replies
Hi, i am designing a tower and i need to see if it will fall over at a certain angle. I have used the centre of mass function as i thought this would be the most suited for the test. I have a centre of mass when the structure is upright and it is perfect, i then rotate the model and do the centre of mass analysis again but the centre of mass doesn't change location. Is there a better way of doing this, any suggestions to help would be great, thanks!
3 REPLIES 3
@oliverchatwin wrote:
...i then rotate the model ...
Are you rotating the model, or are you rotating the view of the model?
Can you File>Export and then Attach your *.f3d file here?
If not, can you post image of rotated model relative to the Origin coordinate system.
I am rotating the model using the move tool, 5.7 degrees to be exact.
Here is the file
