How to successfully upload file to cloud for STL and speed up uploading
memo2022
memo2022
Hi Guys,
How to succssfully uploading the file to cloud for STL and speed up that as it takes 10-20 mins for 9MB. Also, i want to ask how to transfer the object i designed to new window which is called untitled. I attached an object i want to transfer it to new window how? Cheers
jhackney1972
The video will show you one way.  Another is to open you model, save it to the Cloud, then open a new model using the Untitled Tab and save it.  After it is saved, you can browse for the file you saved to the cloud, right click on it and chose "Insert into Current Design" or simply left click and drag it into the save file.  This creates a Linked file which you Break Link if desired.
As far and saving an STL to the Cloud, I would open my model, containing the Body, right click on it and choose "Save as Mesh", place it on your local drive then use the Insert Mesh command to add it to a new model, then save to the cloud.
John Hackney, Retired
memo2022
Thanks so helpful
