How to slope
girard.ibanez
Message 1 of 8
How to slope
girard.ibanez
How do you do a slop on the upper part of the base. See Pic ... Thanks
Girard
Replies (7)
Message 2 of 8
jhackney1972
You need to post another image 90 degrees to the one you have already posted so the Forum users can see what you need.
John Hackney, Retired
Message 3 of 8
girard.ibanez
I don't have another angle but I edited the photo to illustrate the slope
Message 4 of 8
davebYYPCU
I don’t have access to your file.
Extrude the red sketch shape, instead of the rectangle top view.
Or use Draft Tool on the block you already have.
Might help....
Message 5 of 8
jhackney1972
Added the angle (10 degrees) to the top of the base.  The issue now is the fillet around the top of the base.  Model attached.
Message 6 of 8
jhackney1972
I have added a partial fillet to the top edge.  Since the edge varies to the sides as it goes around the inclined surface, it will not take a Fillet.  I used a Sweep Cut but again the same condition prevents me from a full cut.  I currently do not see a good solution.  If I come up with something better, I will post it.  My final attempt model is attached.
Message 7 of 8
jhackney1972
I finally decided on a way to create the top .5mm fillet.  The completed model is attached.
Message 8 of 8
girard.ibanez
Thanks for your help ... took me all night and you solved my issue. Much Thanks.
