Announcements
How to set leading and trailing zeros as default for all drawings?
daves67ABM
daves67ABM
is it possible to set trailing and leading zeroes in drawings as default? I cant see it in settings.
Best regards
David
g-andresen
try this
günther
ClintBrown3D
Hi @daves67ABM
Leading and Trailing Zeros are a Document Setting. Ideally, you would set this up in your drawing template file (.F2T), so that all future drawings use this setting.
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
daves67ABM
This works for individual drawings, does not set as default.
Its bit annoying to set it per each drawing. In old version it was two clicks with minimal movement 🙂
daves67ABM
Maybe add it in Drawing section of preferences in future version?
ClintBrown3D
Hi @daves67ABM
I understand your frustration with the change.
This setting is now configured in document settings, so for existing drawings, this is a few clicks to get to (as you have stated).
My suggestion is that you set up your leading and trailing zeros in your template file so that when you create a new drawing, this is already set up and there is no need to change the setting each time you create a drawing.
Clint Brown
