How to save a file in stl
I'm getting crazy with the problem in the subject; I've uploaded in Fusion a model in stl (an action figure), then I've added a support fo the feet, in orther to give him more stability (a solid base which cross the model's feet); now, when I select the component with the right click and i use the command "save to stl" I have only the support, without the model mesh...how can I export the full project in stl?
masa.minohara
Hi @Anonymous,
Thank you for posting! Could you try downloading the file as STL from the web?
If that does not help, would you be able to share a public link to the design with me?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
where's the STL feature gone in (Unsaved) on Fusion 360?
slentz999
Community Visitor
Community Visitor
How is that the solution? Save as STL was replaced by Save as Mesh in Fusion 360. How can you save as an STL now?
christian.tapkenKLE4M
It is not removed, but renamed as "Save As Mesh". It should have the same functionality, but also can save 3mfs.
