Fusion Support
How to print recess into PETG
1 REPLY 1
salesMUBBN
57 Views, 1 Reply
I have a USB plug that needs to insert into a part. The problem is that inside the recess does not print correctly because of the material hanging in the air. When I pront couter bore holes I do a little trick of 2  x recessed shelve sthat almost fixes the issue but I am not sure what I can do with this irregular "d" shaped cutout.
1 REPLY 1
g-andresen
in reply to: salesMUBBN
just add support structure in your slicer
günther
