Message 1 of 12
I inherited an stl file, which I imported as a solid object so that I could edit it. Unfortunately I cannot figure out the simple edit that I want, which is to keep all dimensions the same except for shortening the long axis (overall length) from 12 mm to ~8.7 (the holes should be 7.5 mm apart instead of 11 mm apart, center-to-center); see attached sketch. Any suggestions on how to accomplish this? link to file is https://a360.co/4e629Dg
