Announcements
How to math in Fusion 360
yraif
Observer
yraif
Observer
Observer
Hi everyone, I'm trying to specify pattern quantity, but even if I use a different parameter and assign value to new variable or directly insert formula into the field, I still get an error.
Is this issue cuz of different units of Fusion 360 capability limitation doing Math
  • math
g-andresen
cannot see the complete quantity (red) term
Therefore.
please share the file for reply
file > export > save as f3d on local drive > attach to post
günther
vladimir_michl
Use the same format as for Distance. So no "=", just the expression returning the value. And make sure your Quantity expression gives unitless results (divide by "1 mm" if necessary).
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
g-andresen
top_holder already exists and cannot be redefined.
However, you can insert (e.g.) “top_holder - 1” into the field
günther
