Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
How to make this shape without seams?
2 REPLIES 2
gsingh_2011
176 Views, 2 Replies
I'm trying to loft between two of the profiles in the image below, with the third arc being the rail.
The result looks like this
I mirrored this to get this result
How can I get rid of the edge/seam in the center, so that it's a smooth transition between the mirrored halves?
I also tried to use sweep/split body instead of loft. I get this shape with no seams
But you can see here the shape isn't exactly right
I've attached both files.
Tags (2)
2 REPLIES 2
jhackney1972
in reply to: gsingh_2011
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Mirroring fit point splines is a bad idea!
After editing one side, often the symmetry is lost.
Peter
Technology Administrators
