Announcements
How to make disappear the Grid on my workspace and issue with the view after selecting the plane (e.g. XZ plane)
s222290629
s222290629
Could you please let me know how can I
- Make disappear Grid workspace and have blank space in my workspace, I want just to learn it
- Based on videos after selecting your plane (e.g XZ) the workspace turn to " top view" and not in 3d, i.e. you can see 2d on your screen, but mine doesn't work like this!!
Kind Regards,
Arman
jeff_strater
for the grid, turn off the "Layout Grid" in the grid control at the bottom:
For the sketch, make sure that "Auto look at sketch" is enabled in your Design preferences:
Jeff Strater
Engineering Director
s222290629
Hi Jeff,
Thanks for that.
My Layout Grid is not active and my " Auto Look at Sketch" is on. but still as the same!
jeff_strater
can you record a video, or at least some screen shots of your session + preferences, so that we can get a better see what you are seeing?
Jeff Strater
s222290629
Hi Jeff,
I found the problem of " Layout Grid", I needed to do it before everything then start to design.
But I am sending snap shot of " Auto Look at sketch" to have a look.
jeff_strater
thank you, @s222290629 - a picture always helps.  Somehow, your sketch environment is set up for 3D sketching.  To turn it off, uncheck this preference in your Design preferences.  If 3D sketching is on, Fusion assumes you do not want to look at the sketch.
Jeff Strater
s222290629
It worked, thank you so much, Jeff.
Kind Regards,
Arman
