Fusion Support
how to make a "3D dimension sketch" into a "solid body"
6 REPLIES 6
patrick_william
189 Views, 6 Replies
here is a video showing what I have got.
thank you
https://www.screenpresso.com/=OLHHb
6 REPLIES 6
1. there´s no solid body
2. sketch > rightclick > add dimensions
günther
Loft the polygon to the point (Apex) in the Solid modeling workspace.
@patrick_william
This will take all of 3 seconds to demonstrate with your actual file.
Tip: Are there any unresolved issues highlighted in your Timeline?
thank you here you go
I don't see where to add dimensions it already has dimensions I want to fill in the cavity shape with solid
create a simple loft body from surface to point
günther
