How to make a elliptical-section coil?
tormy.vancool
tormy.vancool
I'm struggling with this since coils seem to be only circular.
My need is to creata a coil with a circular-section wire.
But the section of the coil itself should be elliptical.
how can I do it please?
Accepted solutions (4)
Replies (14)
HughesTooling
Take a look at the attached file. Just edit the user parameters and the CoilForm sketch to your specs.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
@tormy.vancool wrote:
My need is to create a coil with a circular-section wire.
Bit confused by this. I think you want an elliptical coil, I'm unsure about the bit about section.
Try the attached. I don't really like it but using path with guide rail doesn't keep the round section.
This is with a guide surface.
And this with a guide rail. Creates a single surface but very distorted. You might get better results is the ellipse is more circular.
Mark Hughes
tormy.vancool
Mmm ... ys it's distorted. Too much distorted. the resulting profile should be very linear ...
HughesTooling
Just for reference this is what I get with a more circular ellipse (45x50) and just using a guide rail. File's attached.
Mark Hughes
tormy.vancool
Yes this is a workaround indeed. I understood how it works. Thank you so much for the effort. However it's very cumbersome and not precise. I hope in the future Fusion 360 will have the possibility to add the parameter directly in Helix to get better results
HughesTooling
Here's the file I posted to your other post. Note, you could save this as a part then insert into other designs to reuse so you don't need to recreate each time.
Mark Hughes
TheCADWhisperer
See Attached.
tormy.vancool
Guys both of you have posted now the solution. That's way better.
I have to go through all what you did in order to learn how to do it. because the important is to understand each step
HughesTooling
I've found a bit of a problem. This method using a Sweep to create a path tends to fail if you don't use full turns. The use of pipe rather than a sweep for the wire is good but doesn't seem to work well with partial turns.
With 30 turns I get a good coil.
But with 29.985 like your sample design i get this. Probably only a display problem but using detail controls and setting the mesh to high doesn't help.
Mark Hughes
HughesTooling
@TheCADWhisperer Don't know if you did this for a reason but having the sweep the same diameter as the longest side of the ellipse means you get a broken path and a segmented pipe.
If you make the sweep a bit bigger you get a single path.
and no segmentation.
Mark Hughes
tormy.vancool
Thanks to you guys really by heart. I was able to make it. Without your hint, it was for me impossible
TheCADWhisperer
@HughesTooling
Oops, I was in a hurry and didn’t check.
This is so much easier in Autodesk Inventor Professional that I got aggravated jumping through extra steps in Fusion (that didn’t work anyhow).
tormy.vancool
I have Inventor now, but I'm getting used to Fusion more because I had to finish some project on it ...
tormy.vancool
Guys thank you so much. I completed the video I was working on it to show the anatomy of a Vacuum Tube.
