Announcements
How to join Surfaces and Bodies
letyampuero1
Observer
letyampuero1
Observer
Observer
I Can't find a way to make the surface a body or make the Surface and body join together.
davebYYPCU
Not fillet.
Surface > Create > Patch, Select each edge walking around the hole, when all are connecting, the hole will close.
When the complete model is air / water tight, Modify > Stitch will convert the surface body to a solid.
Might help.....
TheCADWhisperer
@letyampuero1
I recommend that you enable Capture Design History and start over on this design.
