Announcements
How to get rid of a point
infoYYJRS
infoYYJRS
I can get rid of this little blue dot, please help 🙂 Also i can't copy and move the contruction lines why is that?
dsouzasujay
Hi @infoYYJRS,
The point you are referring in the 2D sketch is the origin of the circle and a 2D sketch point.
If you would like to delete the point then click and drag the point, delete the point and the circle.
https://knowledge.autodesk.com/community/screencast/8d4a5524-96f0-438b-bc54-05dca39e4765
After copy and then Paste, you should be able to move the construction lines. If this is not working can you please capture a picture or a screencast video pointing it?
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
g-andresen
1. You can move the point to the center.
   But then you have to move some of the other elements.
2. What do you want to achieve with the construction lines?
Screencast
günther
infoYYJRS
i would like to create a patterne but first i have to draw  the construction lines
infoYYJRS
ideally i would like to duplicate copy and move the first drawing i did. If i could somehow merge the contruction lines into one object.
g-andresen
I can only recommend you to make patterns not in sketch mode but as body/feature in solid mode.
This way you save yourself a lot of problems.
However, construction lines are not suitable for this.
If you would post a picture of a real existing object once, we could give better hints.
günther
