How to fix Error: Position calculation failed due to initialization error?
Fusion 360 just broke my design 😕
With my latest design I tried to follow many best practices:
- structure design as many components
- assembling/joing components while designing
- using parameters throughout the design
After adjusting 1(!) variable/parameter to make my design a little wider, everything fell apart.... It is really hard to tell how I can fix this. Most of my joints broke with the red error. "Error: Position calculation failed due to initialization error"
I have no idea how to fix those. When I try to edit these joints and reselect the contact points it fails with the same error. What is going on?
I attached the broken file for debugging. I am looking forward to ideas how I can salvage my project. Thanks
EDIT: It looks like even just move a single feature in the timelint will cause it to fall apart. Same goes for trying to edit/delete a capture position feature. In each case a perfect timeline (no errors) goes red with the above unsolvable errors and many joints.
