Announcements
How to fillet many edges?
autodeskN884Q
autodeskN884Q
I want to apply a fillet on many instances. I tried it with a circular pattern but that didnt work. An export of my work is attached. Thank you
I have created two distinct bodies like so. A "vase" and a "stripe"
Then I've used the circular pattern tool (70x) so that the single "stripes" overlap
Combined all solids to a single body
No I want to fillet between two "stripes". Like so (seen from below)
But I'd have to select it 70 times manually to use the fillet tool between all "stripes". Is there a better way to do it?
What I've tried is to use the circular pattern tool again. This time selecting the feature of the fillet.
I've tried all 3 Compute Type options but none of them worked
TrippyLighting
Press "F" for fillet.
With the fillet UI open, now to to your selection filters and unselect all and re-select body edges.
Then in the front view, window select edges from right to left, give it a dimension and select OK.
Done!
