How to fill a hole in Fusion
ian1196
ian1196
I have a disk with a hole in it that was given to me. There is no reverse stack. I want to fill the hole. My solution was to make a copy. Slice the copy. Use Plane to trace half of the slice. Remove the copy and revolve the drawing. If the disk were more complex with pins and holes, is there a better way to fill the hole other than copy/redraw? Note the hole is through the chamfer making it tricky.
jhackney1972
In the model, left click on the Face of the hole, right click and choose Delete from the context menu.
John Hackney, Retired
ian1196
That works on my drawing with displayed history. It does not work on a drawing with history removed.
TrippyLighting
Yes, it does! In fact that is one of the main reasons you should NOT enable the timeline for imported geometry right away.
If you have a particular model where this doesn't work, please share it.
g-andresen
imported STEP  (no history) > works!
günther
