Announcements
How to export a design to GrabCAD ?
elpidiovaldez5
elpidiovaldez5
I hope the title says it all !  I want to put a design into GrabCAD.  It's a small, self-contained component that people might find useful.  I have googled and found a video on how to do this from 2013, when the UI seems totally different.
I also found:
  • How to use 'export' off the component right-click menu.  That does something but I don't know what it did !
  • 'Export' off the file menu - only shows local directory system.
Apparently this is so simple that nobody says how it is done, but it isn't simple enough for me.  Please could someone elucidate.
g-andresen
1. rightclick component
2. Export
3. Select file type and location to save as "my design" * > ok
4. upload to grabcad
günther
* your filename
elpidiovaldez5
@g-andresen  - thanks for the solution.  So it seems like the integration directly to GrabCAD described in 2013 by this video got abandoned.
