Hello All
First question ... as you can see on the .pic I have what appears to be offset faces on the bottom of my work piece. I have tried to select and hit delete with no success. How can I remove them?
Second... I am trying to cut the "end" boards so the fit within the octagon ring. Each time I select "line" to cut the angle it takes me back to the sketch area. Is there a way to make the line and then do extrude right on the piece with out going back to the sketch?
Hope this all makes sense and if questions let me know.
tia,
cvbsThis is lookin it from the bottom. The "yellow" areas I can not delete !!
