Announcements
How to delete project version v2
Question from newby: How can i delete a verion of a project?
In my case the projects has two versions v1 and v2.
I want to delete v2.
jhackney1972
You are talking about versions of a file not a Project.  Projects do not have version numbers.  You cannot remove a version of a file.  You can open it then save it by a different name and it will be version one again.  You may want to just designate version one as a Milestone.  This will make it clear this is the primary version to use.
John Hackney, Retired
jeff_strater
you can also open version 1 directly, and do "save as new version", which will make a copy of version 1 into version 3.  Version 2 will still be there, but it will not be the latest version.  Today, there is no way to "prune" old versions of designs.
Jeff Strater
Engineering Director
