You can do the same thing in Fusion 360, open and save a new file, and then insert components from the Data Panel. You can also create components directly in the new file creating an assembly. Create the component first, activate it to make sure all sketches and bodies fall under the component. Make a new component while another component is active to create a sub-assembly. It is pretty much the same.
John Hackney, Retired
