How to create a 180 degree bend in sheet metal over a large radius
jcoyier
jcoyier
I want to create a rectangular bracket to wrap around a 1 inch tube.  This has to be simple but I'm a newbie and cannot figure out how this should be done in F360.  I started with a flange using a custom material of 20g ss.  Looks like sheet metal bends are not designed to handle this type of bend since they will not allow a 180 degree bend.
davebYYPCU
Draw side view of the bracket, make the flange,
(should - don't know about that)
This was then unfolded, for further operations if required.
Might help....
g-andresen
try as @davebYYPCU  recommended
Screencast
günther
jcoyier
Yes, this approach accomplishes what I could not using the "bend" operation.  Thanks for the help.
John
ottooemann
Thank you, this is brilliant! I wanted to punch the screen when the flange bend limit turned out to be <180°
