Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
How to convert a complex shell into a thickened shape
3 REPLIES 3
carlweitman50
168 Views, 3 Replies
I am trying to turn a complex shell to a thickness of 5 mm. I have tried the thicken tool but that didnt work. I also tried making it a solid body to use the shell command but that didnt work either. Please help me!
3 REPLIES 3
@carlweitman50
Are there any unresolved issues highlighted on the Timeline?
Does Ctrl b (CMD b on Mac) return any errors?
yes, there are 10 warnings mostly of them regarding construction planes. it says that the model uses caches geometry to solve. I have linked the file in my main message and i think that it would be easier if you checked it out. Thanks...
@carlweitman50
I recommend starting over from scratch and STOP at the first signal of any issue, resolve the issue or ask questions.
I would not use any Moves in this design.
I would not have any white dots in my sketches and I would strive to more fully dimension my sketches.
