Fusion Support
How to construct an axis at an angle?
4 REPLIES 4
eliJUZP6
101 Views, 4 Replies
Is there a way to construct an axis at an angle?
4 REPLIES 4
TheCADWhisperer
in reply to: eliJUZP6
Yes.
eliJUZP6
in reply to: TheCADWhisperer
Here is the file
jhackney1972
First thing I did was to convert your dome cap into a solid body from a surface body.  I left the development sketch in a visible state so you can see it.  I guessed at the layout sketch apex dimension, you can adjust it as needed.  You can control the insertion depth of the three fittings using the offset values in the three joints at the end of the timeline.  Model, as a F3Z, file is attached.  You will have to Upload it to the Cloud to open it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
John Hackney
Retired
