I have the following complex chamfers that I would like to machine, they are an aesthetic choice so I would prefer to keep the geometry as it is. However I am not getting any of the 3d toolpaths to work. I have tried "touch/do not touch" command on the surfaces, I have tried using "model" to define the chamfer surfaces, I have tried both highlighting the top and bottom profiles of the chamfer independently and together. Each time, that 3d toolpath only seems to either face the top of the part and not the 3d geometry or do something else crazy like machine the entire block of material away. Basically I would like to rough the form in with a 3mm endmill to make rough "stairs" and then come back through with a ball endmill to clean it up. Here are some images of the part and my attempts with scallop:
