one more question to drawings.
In the File I have some components - created directly in it.
Now it happens, that a part (component) is joined under an angle in the assembly.
Not vertical / horizontal to the origin (coordinate system).
Making a drawing from this part is fine. But the part is shown under the angle same to the assembly.
See attached picture 1.
So far so good.
I tried to rotate the view but even if it shows the exact angle for correction.
See attached picture 2.
It does not fit 100%.
See attached picture 3.
And I'm not able to fine tune or align it to another horizontal line.
How can I adjust this view that the measures are also 100% correct?
Thanks for your help.
Best regards,
Bernd
