Announcements
How to align a circle in a sketch along an axis ?
contactNZKMF
contactNZKMF
Hi !
I have a custom axis I created and a cube.
Is there any way to create a circle in a sketch where center is located at the intersection of the axis and an edge of the cube?
(I'm able to create a point at the intersection, but the point isn't available in sketch mode)
jhackney1972
Please attach your model and a screen capture to illustrate what you have and want.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
contactNZKMF
Thanks, there is an export of my model. I'm trying to draw a circle on the top edge of the cube.
jhackney1972
First of all, it is not a cube.  Second, there are four top edges.  Third, you original post mentions something about the axis intersecting the sketch.  Clarify.
contactNZKMF
Sorry, it is a parallelipiped rectangle.
And sorry for mistake, I swapped two words, I'm trying to draw a circle whom center is at the intersection of the blue axis and the face of the "box" located on the "top" (I added a point using "Edge and plane" feature)
jhackney1972
Model and Screencast are attached.   You are looking for the Sketch, Project command.
If this solves your issue, please close your post by clicking the Accept Solution icon on the post that solved it.  If you have further questions, please ask.
contactNZKMF
Thanks for your help !
