Can someone please help with. how to add "3D print" command to menu bar?
or' what is the keyboard shortcut to "3D print"?
thanks
Ilan
Solved by HughesTooling. Go to Solution.
3d Print is only available on the utilities workspace. You can set a keyboard shortcut from the icon in the utilities workspace that should work in other workspaces, just click the 3 dots in the menu next to 3d print.
Mark Hughes
Owner, Hughes Tooling
Thank you so much for this screenshot and answere !
I am new to Fusion 360 and just now realized the UTILITIES workspace was up there in the screen 🙂
I changes the the keyboard shortkey to "P" and my life is so much easyer now.
this is a great cummunity. happy to be part of it.
Ilan
Note that the shortcut P is defined for the projection tool.
günther
