Fusion Support
how to access the "lockingring.f3d" file in autodesk's own tutorial !?!?
5 REPLIES 5
kdas2000-autodesk
246 Views, 5 Replies
I'm going through the  CAD for Mechanical Design Associate Certification Prep .
I'm in the Create And Modify Sketch section .
The step says to  upload and open the supplied "lockingring.f3d" file .
I don't see how to do this .
? Is this restricted / unavailable because I have a free / learning license ?
5 REPLIES 5
@kdas2000-autodesk
Do you have a link for the tutorial?
Hi, Here's the URL I'm using to access this tutorial...
CAD for Mechanical Design Associate Certification Prep - Create and define sketches | Autodesk
CAD for Mechanical Design Associate Certification Prep - Create and defi...
Please try to post the link again as it does not appear in your reply.  You cannot add it using email, you must post it in a reply post on the Forum.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
I have looked for the dataset for about an hour and have not found it either.
John Hackney
Retired
