Announcements
How does one find the center of gravity of an object?
How does one find the center of gravity of an object and attach it to a block which will serve as the mount?
ltomuta
Right click on the body, open Properties and read the coordinates of the center of mass.
jhackney1972
This blog article and video will help you place a sketch point in your model.  Once positioned you can use it as an assembly Joint reference.  Note: this point is not associative, if the model changes the point has to be re-established.
John Hackney, Retired
